Mobo question about 4870 X2
I believe you can due to the crossfire bridge being on the card as opposed to a chipset on the MB. I'm sure someone else could explain it better than me though.
It should be fine it will work as far as your mobo is concerned as a single card. Unless nvidia have done something you shouldn't have any more problems running it then an intel user would have.
