Mobo replacement, what one?
28 Jun 2005
Behind you
Hi,
Been getting hardware failures in Vista and I think its the mobo as ive tried different ram and 1 gfx card at a time. Should I get another nforce6 or go for nforce7? Also, which one is very stable?
thanks
they say EVGA is 1st choice (with step up program etc etc) But I've got an XFX and the support for that is great, enough I've not had to use it much, just in terms of bios updates etc.
And to be fair, I believe they are all reference boards, so getting the latest BIOS from XFX will work just fine on the EVGA and vice versa
can't fault the xfx 780i, not had any experience with the evga version, don't forget they are both reference boards so differences will be very minute
