mobo rgb fan help
7 Nov 2013
Corby UK
hello all,
finally got the parts i wanted and now running into 1 issue of which i cant figure out.
anyway these are the parts i have just purchased
thermaltake view 32 case
geforce 1660 super oc
16gb corsair vengeance 3200 ddr4
thermaltake smart 600w psu
Ryzen 5 3600 cpu
MSI X470 Gaming Plus Max mobo
now my issue is everything seems to be working fine except i can not figure out were to connect the last rgb pin onto the mobo to be able to change the rgb colour settings from the top control panel on the case itself.
There are 2x 5050 RGB LED strip 12V connectors on this board, one at the bottom edge(near the clear cmos button) and the other between the PCIE slot and CPU socket.
