- 12 Apr 2009
Hi guys,
So I just cleaned out my water cooled system and put it back together. When I press the ON button the computer switches off after 1 second and attempts to start back up again, and it keeps doing this.
So I disconnected everything and it boots up fine - after connecting everything one by one it seems the culprit is the 8 pin CPU connector to the MOBO. I don't know why or how this has happened but any input would be of absolute help. The points I think you guys should know are:
1. I added a new Intel SSD so the previous HDD (with Windows and all the drivers on it) is now being used a slave drive to the new SSD (which I haven't installed anything on yet).
2. When disconnecting the cooling system a little came out of the rad and spilled on the PSU and a few splashes on the MOBO. Luckily it weren't a lot and I managed to dry it all off but looking at where the water had gone it was only on the surface of the MOBO and PSU - so I HOPE there isn't any internal problems but I don't think there is.
