Mobo suggest for mITX or mATX with WIFI
25 Apr 2011
Crawley/Gatwick
I am after a board for a mITX/mATX build
Something with usb3.0 & sata 6gb
Lowest price possible, so far cant really find anything cheap
can be z, h, b etc. Thanks :)
Asus Vanguard B85 is also a good shout (if you aren't going to overclock), because it's built to last longer than most (5 year warranty). It's one of the more expensive B85's but the cheapest motherboard with a 5-year warranty. It can also run 2133MHz memory.
Yeah, the reason why mATX board don't come with it built-in is because they have the expansion slots necessary for the user to add it themselves. mITX usually come with it because they don't. Wireless cards aren't terribly expensive...
http://www.overclockers.co.uk/showproduct.php?prodid=NW-043-AS&groupid=46&catid=1597&subcat=1622
Or
http://www.overclockers.co.uk/showproduct.php?prodid=NW-025-AS&groupid=46&catid=1600&subcat=2033
Here's a mITX suggestions too whilst you've already had some mATX ones:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-268-MS&groupid=701&catid=5&subcat=2071
http://www.overclockers.co.uk/showproduct.php?prodid=MB-494-GI&groupid=701&catid=5&subcat=2071
Both have WIFI already, but as said it would be cheaper to get the £58.99 Asus H81I linked above and use a USB adapter.
basically best option is to go for mATX with dongle or addon card?
I have z87i mitx board but its a bit expensive
Thanks for the help guys, didnt come across dongles in a while, thought they were obsolete
