Just built my pc that I ordered from here on thursday
Everything seems to be running fine, just out of interest I ran the ASUS PC Probe II and it seems my MB temp is 49c, and thats idle?!
My room isnt particularly hot, case fan is on (Lian li pc7 with 120mm case fan), cpu is showing as 25c
Setup is q6600 +airctic freezer 7
8800 gtx
corsair hx620
asus p5k pro.
Is this temperature ok? Im downloading everest now to double check it, seems a bit high for my liking but dont know whether to trust it!?
cheers!
Just checked everest and thats saying 49c also, gpu is 62c.
Also, running everything at stock speeds.
8800 gtx
corsair hx620
asus p5k pro.
cheers!
