.paradigm said:Get something intel P35 based to be quite honest. Why buy old tech?
Abit IP35-PRO would be my choice.
They overclock better full stop, not just quad-core.
A £120 motherboard for a £55 CPUparadigm said:Get something intel P35 based to be quite honest. Why buy old tech?
Cob said:A £120 motherboard for a £55 CPU
I agree with Walter. The 650i chipset is pretty damn good, whilst the DFI P965-S dark is dirt cheap for what is considered to be a top-notch board. Yes the P965 chipset is older than the shiny new P35 boards, but it's more than enough for an E2160.
Cob said:A £120 motherboard for a £55 CPU![]()
Hmmmm £58 for a top-notch P965 DFI board or £70 for a 'budget' P35 boardeasyrider said:EVGA nForce 650i Ultra (Socket 775) PCI-Express DDR2 Motherboard (122-CK-NF66-T1)
£49.99
£58.74 inc VAT
or 12 quid more for the P35 Abit?
HMMMMMMM![]()
Cob said:Hmmmm £58 for a top-notch P965 DFI board or £70 for a 'budget' P35 board![]()
You seem to forget that the vast majority of people buying an E2160 have no intention of upgrading to a quad-core in the near future (near as in the next 24 months), and Penryn is still a town somewhere and not something they're going to be dribbling over shortly.
Bang-for-buck is the P965 DFI. And that matters to most people when buying computer components.
I think mainstream would be a better term. Just like the P965 and P35 chipsets are.easyrider said:I wouldn't call the DFI Infinity P965-S Dark a top notch mobo.
Its a budget DFI like all infinitys are.
Cob said:Well the IP35 is a better board than the IP35-E.
But if you're on a budget I would get the DFI and spend the £30 difference on something else. Maybe get a good cooler that lets you clock the nuts off the E2160, or maybe get a better graphics card if you're intending to upgrade it too.
Cob said:I think mainstream would be a better term. Just like the P965 and P35 chipsets are.
The Infinity was something like £120 when it was released a couple of months ago.
On OcUK the IP35 (which the OP is considering) is £88 and the Infinity is £58. That's £30 by my calculations.easyrider said:For starters the Abit P35 is not 30 quid more.Its 12 quid more..
Over on XS the clocking is nearly on par with the pro.
The heatpipe or lack of is no biggy due to the fact tat the chipset runs so much cooler than the 965 like on the DFI.
For 12 quid extra its a no brainer.
There is a reason why the DFI so cheap.
easyrider said:a quad was 350 2 weeks ago...
your point?
Cob said:On OcUK the IP35 (which the OP is considering) is £88 and the Infinity is £58. That's £30 by my calculations.
And state the reason, dude. If there's something the OP needs to know about the Infinity then at least tell him.
It was £240 or so 2 weeks ago. Mine was £380 a few weeks ago.
And the point is now that both the Infinity and the Q6600 are the same as they were before their price drops.
Surely you of all people aren't trying to say that the Q6600 is now crap just because it's dropped in price.
