Thinking of buying an Antec 300 and whilst I'm getting lots of encouragement that it is a good case, I'm concerned by the number of people who have said that I need to cut holes in the Mobo tray.
I've done some research and I understand the rationale - to keep the PSU cables tidy and to prevent them from obstructing air-flow.
But I'm a bit daunted about how to do it. I've seen guides about using hole saws - I have some hole saws that came with a drill set but as far as I'm aware they are for wood only.
I have a dremel but can't imagine how I would cut neat circular holes with it.
The guides also talk about bottom mounted PSUs being a particular problem and suggest turning them upside down - of cours this means cutting a great big hole in the hottom of the case for the fan.
Any opinions on this - is it worth it - it's really putting me off the Antec 300 because I've never had to do this thing before but then again I've never had a case with a bottom-mounted PSU.
Cheers,
Nigel
Cheers,
Nigel
