- 6 Feb 2019
Hi. I'm planning a build and I've picked a case that has a front panel usb c. I was planning on using the b450 tomahawk motherboard ( maybe max ) so I found a build vid where he was using both the case and the board but he said there wasn't a usb c connection on the mobo to make use of the connection on the front panel. I want to be able to use it so my question is , as I'm not up with the jargon. When choosing a mobo what do I look for to make sure it'll have the right connection to make use of the front panel. I've seen some that say usb c but I'm not sure if that's a front panel connection or a connection out the back.
The case was a nzxt H510 elite , and it will be a Ryzen build. Thanks.
