Mobo with PCI-E that won't be block by 8800GTX
pci-e network cards have zero advantage over regular pci ones because their bandwidth is way lower than even regular pci but i dont think theres any motherboards where theres a pci-e x1 slot before the x16 one
PCIe x1 has 264 Mbps of bandwidth, PCI has 133 Mbps.
HEADRAT
My asus p5ld2 has
From top to bottom:
pciex1
pciex16
pci
pci
pci
pciex1
pciex1
eracer2006 said:
true but standard network speed is 10/100 and therefore theres no point in needing more.
network speed up to 1000 now...(My motherboard has 2x 10/100/1000 LAN sockets)
got a evga 680i with 3 pci-e slots. top oe is occupied by 8800gts middle one has a an lsi logic SCSI card and fits in there nicely without obstructing the gfx card. hope that helps
Concorde Rules said:
Then why do you need it!? :confused:
Do you transfer large files a lot? As in 4gb+?
If you dont then there is no point :/
I use to transfer a lot of movie files back and forward between my main PC and my media PC..As i used to keep all my DVD movies ripped to my int harddrives..
(But now i have most of them on 300gb & 500gb ext SATA & USB2 hardrives ,so i just plug them into whichever PC i want to use them on)
Gigabit lan is awesome for raided NAS, normall 100 megabit lags it a lot.
Hell, 100mbit isnt even enough for proper remote desktop, when you're watching a film over external desktop, on 100mbit it might lag the sound, I've had that happen very often.
