mocking jay part two problem
6 Sep 2016
Panasonic 820 player latest 1.60 firmware
With hunger games mocking jay part two around 11 to 15 minutes it jumps around going from VTOL take off to katniss and Peter talking, to being underground with the gollums, to broad daylight talking to the military guy about keeping her alive.
This is the second replaxment disc. Discs have been scratch free and both behave exactly the same.
Known problem or to do with my player?
Do you have another player you can try it on?
It sounds like it might be a bad batch of discs as for it to last ~4 minutes rules out the normal things like layer changes.
[edit]
I've done a bit of googling and it does look like panasonic's have an issue with that disc for some reason, skipping/being unable to play it.
We had this problem with the Blu-ray on this player. Had to buy the 4k edition (box set with rest of movies) which played correctly! Must be a compatibility issue with this disc specifically as the other blu-rays played fine. 4K disc has much better picture and sound anyway!
I assumed you meant the 4k Blu-ray disc which works absolutely fine, I'm watching from 11 minutes now.
VTOL takes off, Katniss talking to Hemsworth (not Peter) then shes about to do an interview then a train pulls up
I'll try the standard blu-ray disc now.
Standard blu-ray disc is indeed ******, the movie jumps from VTOL taking off to suddenly they are underground which is fairly late in the movie I believe then back to Katniss talking to Hemsworth. Must be some branching issue with this disc.
That's not right.
Buy the 4k disc :)
It's the regular 1080p disc. Works on PS3, old Philips bdp3000.
Got another disc, does the same.
So either issue with incompatible with the player or the panasonic doesn't like the layout.
