Mod_Rewrite question.
27 Jun 2006
Evening all - fairly new to this, but I have the following file stucture on some webspace (helping a friend, not my site or structure!)
public_html (www.domain.com)
|___directory1
|___directory2
At the moment, the htaccess file has the following lines in it to push all requests to the domain name to directory1. IE: www.domain.com ->www.domain.com/directory1
This worked fine until he added directory 2.
Now if he browses to www.domain.com/directory2 firefox throws an error:
"Firefox has detected that the server is redirecting the request for this address in a way that will never complete."
which I am guessing is something to do with the htaccess file.
I am no master on htaccess but I tried the following but it still doesn't work:
Code:
Options +FollowSymLinks
RewriteEngine on
RewriteCond %{REQUEST_FILENAME} -f [NC,OR]
RewriteCond %{REQUEST_FILENAME} -d [NC]
RewriteRule (.*) http://www.domain.com/directory1/$1 [R=301,L]
Any help kindly accepted :)
That rewrite doesn't even work if I upload it to a site...
Is it terribly important for it to be a rewrite? i.e. for SEO purposes? I would just use a php redirect.
Just make an index.php in the root dir and put:
PHP:
<?php
header( 'Location: http://domain.com/directory1/' ) ;
That's how I always do these kinds of things, is there a reason why this redirect is in place in the first place that can't be fixed?
I don't really know why it has to be done in the htaccess file, I foolishly thought I would give a friend a hand (if only I knew it was the voodoo that is rewrite I would have run away!)
I may try to push him the way you suggested as its easier and I understand it!
Cheers
Do you want all requests which go to Directory2 to also be sent to Directory1?
Using the rewrite above if I go to:
/directory2/index.php
I get forwarded to:
/directory1/directory2/index.php
without any loop errors.
Have you got another .htaccess file in Directory1 ?
Thanks for that - no other htaccess anywhere (I had a good look as I was pulling my hair out!)
In the end I persuaded him to dump the htaccess and go with a PHP redirect, so its now happy (and a lot easier for me!!)
PHP:
<?php
He's using a 301, so it is for SEO purposes :)
Still doable in PHP though.
Code:
Header( "HTTP/1.1 301 Moved Permanently" );
Header( "Location: http://www.new-url.com" );
But yeh, I would change to this code as Google will find that site as 302.
