Hi,
I was wondering if any of you have modded your 360's in anyway? I already own an elite but was thinking of looking on the bay for a damaged one that I coulf rip apart, fix and maybe mod the case, or build a new one from scratch.
I'd love a little R2D2 360
Anyone know of decent websites with some on?
Thanks
Thanks
but its almost quiet so not bothered about the back anway as you hardly ever see it. Also not bothered about the ban hammer from MS as thats an urban legend about people getting banned for changing their fans for different models. As long as you dont go silly with LED bling & or other voltage sapping mods it will be fine. You can also add an 80mm fan above the GPU HSF by cutting the case above then fitting a fan grill which would then increase the cooling a little more along with replacing the MS thermal compound for something better (I left mine for now as it seems fine for over 29 months so why change it!).
