modding antec 300 for cable management
16 Aug 2003
Worcestershire
Hi guys,
Planning on getting an antec 300 shortly for a new build and first venture into a little modding!
I will eventually be spraying it matt black throughout(seen another thread on here with pics and it looked great!)
Before spraying it I want to cut some holes in for cable management to run cables behind the mobo/side panel. Does anyone know where I could look or what I could use to add a rubber seal around the holes I make?
I could just sand the edges down until nice and smooth but would rather have rubber edging around them if I can find anything.
Thanks.
I use rubber grommets on my builds, between my old man being a plumber, my brother being a sparky and my wife's dad being a motor mechanic.. I have plenty to choose from.
I use the blanking/blind/bung grommets, make a nice clean horizontal insertion with a Stanley/modeling blade and push the connections through. This way the cables do not rattle/vibrate with any movement
thanks guys, ordered some 'blowhole trim' ;) as it is <£1 per metre so will give that a go.
Ordered my case today so when it arrives will get busy with cutting holes and spray painting :)
I've decided to drill out the rivets when I get the case to make it easier to cut and paint. I have been looking for where to get some replacement rivets but don't really know what to get.
Would 3.2 x 6mm rivets be the best size to get?
Also, any advice for cutting the mobo tray? I don't have a dremmel so was thinking of just taping up with masking tape and using this type of drill bit -
Looking forward to getting started now :D
if you search this forum (case) for anetc 300 you will find a pic of what someone did with a drimmel.
I did the same and works great.
Post up some pics when you have done it.
Will do, should be arriving tomorrow so when i get chance i will take some before, during and after pics if i remember.
That's the sort of thing I'm thinking of, but want to cut the holes, then spray the chassis black as want to put a window in at somepoint in the future and love the look of the matt black internals that someone else on here did
Why do you need to mod the antec?
I think the cable management is quite good...
Similar to the mod linked above I just want a hole near the psu at the bottom and maybe 1 or 2 around my mobo (depending where connectors are) so that I can run as much cabling as possible behind the mobo tray and out of sight.
I think I'm going to hold off on the rivets until I get the case and see how easy it would be to spray without taking a part, ideally I would rather not have to drill out and then replace every rivet if I can still do a good job without taking apart.
Sorry for the delay guys, these are the pics so far. Nothing fancy or special, just a couple of holes around the mobo to run cables behind -
1st Hole drilled - I actually melted my finger tip as stupidly I picked up the disk of metal case straight after cutting it out and it was red hot!
Holes at the base of the case near the PSU.
Joined the holes together with hack saw - not very straight at this point but will look ok once it has got trim around.
Holes with edges sanded smooth and blowhole trim around the edge. I will make the trim on the top hole neater when I do it properly after spraying.
That's all the pics I have for now, I have actually finished all of the spray painting so will get these pics up when I can.
Paul.
I built a system recently for a friend based on the 300. I also made a couple of cable management holes. Didn't plump for the one at the PSU, but I did increase the size of the little hole near the top at the back of the 5.25" bays to allow the optical cables through....
Nice work that..:)
