22 Oct 2013 at 13:15 #1 Lisapete Lisapete Permabanned Joined 21 Sep 2013 Posts 1,336 How easy is it to do? Which one is the best? I need to add a GPU block to the loop. Can you buy the pump/block only?
22 Oct 2013 at 13:34 #5 Lisapete Lisapete Permabanned OP Joined 21 Sep 2013 Posts 1,336 Sorry, the likes of an Antec or Corsair All In One, pre built etc etc? I have a very very small case and problem finding GPU HSF to fit my card but I can find water blocks just like that
22 Oct 2013 at 15:29 #9 Lisapete Lisapete Permabanned OP Joined 21 Sep 2013 Posts 1,336 Lian LI PC-TU100 http://www.lian-li.com/en/dt_portfolio/pc-tu100/
22 Oct 2013 at 18:09 #11 Lisapete Lisapete Permabanned OP Joined 21 Sep 2013 Posts 1,336 I never said I am over clocking.
22 Oct 2013 at 20:33 #13 Lisapete Lisapete Permabanned OP Joined 21 Sep 2013 Posts 1,336 If I mod, got too work out how to get the front internal section apart Measured with fan removed .... 55mm edge of motherboard to inner frame fan removed 70mm edge of motherboard to very front of case internal frame removed I could relocate the SSD's and fit a very slim rad and fan combo in the base there. I have brackets from the USA to mod the Antec Kuhler H20 620 onto a Nvidia GFX ''TripTCC Corsair H60/H80/H100 GPU Bracket'' Then I'd have 2 small systems crammed in the case!
