Hello everyone againg. well as u may know, i have this case.
Thermaltake Xaser MX (VH9000BWS)
if u check picture u will notice where i want to make the windows, on the plastic transparent x shape window off course.
i want to make some custom mod/hardmodding on it. i want to put a 80mm and 120mm in the window. also i would like to hear some options or something cool that can be done with this case. i havent found any picture or even a comment about this case, and the modding possibilities.
please help me about how i can do it, or what could be nice looking. i think about the fans because of the cooling solution (9800gx2 heat-monster card, that "·!%% raises temp 10-20%). i just want it to have a better ventilation but i want to hear about options.
also i have another problem with this case. the power x shapen boton led, its a 3pin conector. i use a evga 790i ultra sli board. the power led conection is 2 pin, how do i make to turn this led on? i have tried to conect it to the 3pin fan conector but it doesnt work. so anybody helps?
