- 23 Aug 2007
Hay all.
I was thinking of removing the side fans as i am not sure if that makes cooling worst as it disrupts air flow coming from the front of the case ?
If i do remove them then i would replace the fan grill with Plexiglas.
Then use the 3 fans and place them in the front for more air coming in or cut a hole in the top and place them there.
I do have 4 120mm fans at the front already but was thinking of putting one at the top instead of the the 3 little ones as there a lot longer.
Thanks for any advice
