Model kits?
12 Aug 2016
Hi Guys,
looking for model kits for friend. I used to do this but my friend is still into it (has about 100 of F-16s alone...) and now he is looking for certain models he could not find. The models are:
F-CK-1 CHING-KUO
IAI LAVI
AMX
MIRAGE 4000
AH-56 CHEYENNE
CSH-2 ROOIVALK
Preferably not pre-painted and 1/72 scale.
Do you guys know where to find these at reasonable prices?
Thanks.
Have you had a look in the local area to see if there are any independent stores that might stock models, even if they don't advertise stock of the specific ones you want? I've found stockists are quite often passionate about models, and if they don't stock it, they can probably order it in or tell you who can. I don't think they're generally in it for the money.
Thanks for the directions guys, managed to find half of them in these shops. Now to spend some money (the best kind: somebody else's :) )
As for
Google it m8?
, I did but there are a lot of search hits that are either non-UK or turn out to be irrelevant and with a full time job, a wife and two toddlers on my plate I thought I'd ask for help.
Thanks again guys.
Definitely recommend Wonderland models as ive recently ordered a lot from them with no issues and they stock a fair bit
As for
Thanks again guys.
Time tunnel models for anything Tamiya
