13 Mar 2025 at 14:45 #1 jonww74 jonww74 Associate Joined 6 Nov 2012 Posts 33 Hiya, how many posts need to be made before they no longer need moderator approval? Cheers.
13 Mar 2025 at 15:03 #2 Bluecube Bluecube Soldato Joined 20 Feb 2011 Posts 4,407 Depends how suspicious you are
13 Mar 2025 at 15:15 #3 MrRockliffe MrRockliffe Soldato Joined 14 Apr 2014 Posts 8,098 Location Hampshire Roughly 350.
13 Mar 2025 at 15:15 #4 Thekwango Thekwango Soldato Joined 5 Feb 2009 Posts 17,376 Location N. Ireland MrRockliffe said: Roughly 350. Click to expand... tree fiddy - jesus!
13 Mar 2025 at 15:58 #5 MrRockliffe MrRockliffe Soldato Joined 14 Apr 2014 Posts 8,098 Location Hampshire Thekwango said: tree fiddy - jesus! Click to expand... Or was it 69? I can’t remember
13 Mar 2025 at 20:58 #6 sigma sigma Caporegime Joined 13 Nov 2006 Posts 30,100 MrRockliffe said: Or was it 69? I can’t remember Click to expand... That's closer to reality (bites). Which is, it depends how much you well you treat the mods. After 13 years I suggest OP has a lot of work to do yet.
14 Mar 2025 at 11:11 #7 jonww74 jonww74 Associate OP Joined 6 Nov 2012 Posts 33 sigma said: That's closer to reality (bites). Which is, it depends how much you well you treat the mods. After 13 years I suggest OP has a lot of work to do yet. Click to expand... Ha, yes. Don't think I'll even make 69 in my lifetime at this rate
17 Mar 2025 at 16:58 #8 Jonny69 Jonny69 Man of Honour Man of Honour Joined 3 May 2004 Posts 17,728 Location Kapitalist Republik of Surrey MrRockliffe said: Or was it 69? I can’t remember Click to expand... You called?
