- 9 Sep 2007
Had a new baxi solo ch boiler fitted as my old one was getting a bit loud in its old age but the modern ones make even more noise ,you can really hear them fire up with a boom which would be ok but they do it every 4 mins so its damn annoying ,called out baxi to check it but thats normal
Anyway I'm thinking of in casing it some sort of wooden cupboard but not sure it will make much difference
