Modern case with USB3.2 etc., 4x 3.5" bays
20 Mar 2023
Ireland
Hi all,
I've been using an old but gold Antec 300 case for the last several years.
The front USB connectors are on their last legs, and are USB2.0.
I like the accessible design of modern cases, and the magnetic dust covers.
I'm thinking it would be wise to upgrade to a more modern case.
The thing is, I have 3x 3.5" hard drives that I want to keep,
Model Family: Western Digital Caviar Blue Serial ATA
Device Model: WDC WD5000AAJS-00YFA0
Model Family: Seagate BarraCuda 3.5
Device Model: ST8000DM004-2CX188
Model Family: Western Digital Blue
Device Model: WDC WD10EZEX-08WN4A0
A single 2.5" i'd like to keep (it's still decent for OS boot)
Model Family: Phison Driven SSDs
Device Model: PNY CS900 120GB SSD
(And 2 NVMe SSDs which aren't really affected by the case.)
Model Number: WD Green SN350 2TB
Model Number: WDC WDS100T2B0C-00PXH0
Just wondering if anyone has any suggestions for a modern and entry-level (relatively affordable) ATX tower case that supports 3x 3.5" drive bays, and at least 1x 2.5" drives. Thanks!
I was thinking of going with this case (Carbide Series SPEC-05),
as it has all the bays that I require,
Then I remembered that I had some mesh I had ordered from China.
I was able to insert the mesh in front of the fans so it should prevent any pet dander/hair getting in to the components inside (hopefully).
I have a Fractal Design Vision case and that supports 3x 3.5 HDD`s and a 2.5 SSD, plus whatever m.2 drives your motherboard supports, depends on you budget really but you could always look at the second hand market.
