Think they are the best APU going right now but they are very expensive.Are the new AMD "AI" chips any good for light gaming (thinking roblox etc) or what's the best AMD "APU" currently available? Quite fancy getting something for small form factor for the kids to play games on
AMD claim like a 4070 but thats probably optimisic maybe 4060 mobile.
Just to be clear, if you're buying for that reason, you're aware that the IGP is the same, right? The 7000/9000 both use RDNA2, but you need RDNA3 for AV1 support.I think AMD iGPU's need to work on this, get them using AV1 or at least use HEVC.. its such a difference to H.264.
If this 9700X3D is real I might just buy one as I know it'll handle these tasks a tad better than what I already have![]()
Yea I know its the same iGPU, but with the 9000 Series being better chips it helps running other stuff at the same time. An example would be how I set the iGPU to be used for Serato Dj Pro when I Dj while being logged into a virtual world (Second Life = loves CPU power) and doing other stuff so IPC gains etc will give me more performance in that while still using the iGPU if that makes sense.Just to be clear, if you're buying for that reason, you're aware that the IGP is the same, right? The 7000/9000 both use RDNA2, but you need RDNA3 for AV1 support.
