Is it possible, with a little modification, to control my VF-900 via the fan header on the X1900 PCB?
At the moment I have that little fan controller sticking out my case making the place look untidy. I keep also forgetting to actually turn it up and down as needed. I prefered it when the system monitored temps etc and adjusted the fan speed accordingly.
The plug currently doesnt fit, but it is a 3 pin plug and with a bit of plastic removed would fit. Question is, would it work?
SiriusB
SiriusB
