Anyone else had this issue before with modular power cables not clipping into their PSU?
I've got a Cosair AX 760 and right now on the PSU end the 24 pin connector is split into an 18 pin and 6 pin. The 6 pin clips in whilst the 18 pin even with a ridiculous amount more pressure will not go the last 2mm into the socket and therefore push over the clip above the socket.
I don't see any obstruction and I've never had this issue with any other PSU... I'm wondering whether I'm missing a trick here... or do I just man handle this thing until it goes?
As I don't want to be running a machine with the main power cable to the board loose. :/
