You can buy connectors, cable and tools from ebay or certain retailers but can't mention the retailer due to forum rules.
Buying premade cables will be trickier as each PSU manufacturer uses their own designs and pinouts so they are generally not compatible with one another.
The connector number is 39-01-4051, or 39-01-4050. The difference is the temperature rating UL94V-0 vs UL94V-2, although I forget which is the better one.
They are the right connectors. I'd be very surprised if they are different. Bear in mind that the eBay page and the Molex page both show the 3 circuit connector but actually are the full 5 circuits when you check the drawing.
