Hi,
I am putting together a new build i7 PC but am having problems trying to find the correct PSU. I will probably go with the Antec 1200 case as I will need some storage and room, along with an OC i7, 6 gb RAM, 3 hard drives for starters, 2 dvd's and a single GPU but may well go for a second at some point. So knowing that I have 2 real questions.
1) I want to go modular to keep cables to a minimum. But what power rating would be good enough to run the above specification with a bit of redundancy built in? Quiet would also be good.
2) The Antec 1200 is quite a big case - and I want to keep my cabling as out of the way as possible. Will the standard cable lengths ln the PSU allow me to route the cables as I would wish on such a large case without having to use extension cables? Are there PSU's out there with a longer cable run than others that also fit the first criteria?
Many thanks for your responses.
