Modular to PCI E Power Leads
5 Jan 2009
Hi all,
I've bought a second GTX670 to pair up with the one I have. I don't have enough spare molex (4 needed) to power the second card, and my PSU (HX620 Modular) only has two PCIE power points (6 and 6+2).
Instead of using those gash 2x molex to PCI adapters, can I get standard modular to PCIE power lead?
Like in this image, the ones on the right that are 1x4 pins, instead of 3x2. Can I get cables that will convert directly from the 1x4 to PCIE?
Don't know if it just me but no image is showing for me.
However I'll mention that nearly every modular PSU has different pin layouts on the psu end to prevent the wrong cable being plugged in. So I doubt a generic one would exist for your psu.
My rule of thumb is that if a PSU lacks the connectors you require then it wasn't designed for that workload and that you need a higher capacity psu.
