- 29 Jun 2004
I understand the stuff, I just need to know why! It's not a h/w thread! It's a "Why is it?" thread!
Right, i'm at home revising for Core 3 Maths A2 Level! Just going through some modulus stuff as I always loose marks there.
I understand that when
y=|f(x)|
x>0 drawing y=|f(x)| is the same as drawing y=f(x)
x<0 drawing y=|f(x)| is the same as drawing y=-f(x), hence a relection in the x-axis
y=f|(x)|
x>0 drawing y=f|(x)| is the same as drawing y=f(x)
x<0 drawing y=f|(x)| is the same as drawing y=f(-x), hence a reflection in the y-axis
Now, that's all jolly good. I understand that, however, when i'm drawing the function it always helps me to draw in two parts. Let me give you an example.
Example
f(x)=3x-2
If I draw y=|f(x)| the drawing will look like y=3x-2 and y=-(3x-2) combined. Like so:
HOWEVER, If I draw y=f|(x)| the drawing will look like y=3x-2 and ??WHAT?? combined.
Like so:
All I need to know is what the hell is my missing function!
I can still do it without knowing it, but it will make my life A HELL of a lot more easier if I knew how to figure it out! And it's not just that example. I want to know how to work it out for any modulus question
I'm sure it's something easy!
Help
y=|f(x)|
y=f|(x)|
Example
f(x)=3x-2
Like so:
Help
