Just rebuilt my PC using a XION II Black gaming case which has three fans, one front, one on the clear side and one at the rear.
Problem is these are connected direct to the PSU via Molex, not via the fan controller on the mobo with the result that they spin at full speed with no means of slowing them down. Quite noisy too.
Is there any sort of adaptor I can purchase which I can place in the circuit or connect via the mobo controlled case fan connection to quiten things down a bit.
Or is it my fault for buying a cheap and nasty case?!
