Molex Connections
13 Sep 2007
Gloucestershire
A 4 pin molex connector,gives 0v, 12v and 7v and 5v? Which pins are which? Anyone got a diagram? Yes i know i could stick a multi meter on end but dont want to blow the meter if i get it wrong.
Cheers
Sheldon
I guess you're looking at volt-modding for a DIY fan-bus?
Yeah, it's +5V Red and +12V on the yellow. If you run a fan between the +5 and the +12 then you have a 'potential difference' of +7 which is where you get the 7v (middle speed) from.
Im going to do this at weekend, I presume I have to cut the cable and put in in small 5amp connector blocks, or is there an easier way?
