Molex passthrough passthrough
Man of Honour
22 Jun 2006
I have 4 80mm case fans in a single case (yes it does sound like a turbine :p) that each have molex passthroughs built into the 4 pin adapter. As I don't have that many molexes (especially with 2 IDE hard drives), is it ok to daisy chain passthroughs? (i.e. connect them one after the other: >>>>) I'm not missing some important rule on how to use passthroughs or overload your power supply?
Pic here:
http://www.antec.com/productImage.php?ProdID=75080&SetZone=en
Yeah, unless you do something silly like run delta focused flow (screamers) or vantec tornados, then you'll be fine. If you do, then you'll be needing a supply of earplugs instead. :)
