Monacle me a routine (2 day split)
13 Aug 2004
England
Hey all,
What sort of routine would be best for a 2 day split? I won't be starting it until the end of march, it's for cutting. So on the 3rd day I'd be doing cardio.
I've seen different types, such as push/pull (not sure what this one is about), and upper/ lower body workouts. Wouldn't the latter have more excercises on the upper though?
Any help apprectiated, muchas gracias!
[edit] I'd like to stick to 6/7 excercises maximum for each day!
Monday - CHEST/TRICEPS/SHOULDERS
Wednesday - LEGS/BACK/BICEPS
Friday - CARDIO
Stick with compound exercises. I was going to post some exercises, but I'm guessing you already know what works for you. :)
That looks good, I can add in abs with cardio.
What i'm also wondering is the big 3 (bench, squat and DL). Should I do more than one in one workout?
I don't see any reason why not. I'm sure a lot of us have done full body workouts before with all 3 of those included. :)
Bench Press 3x10
Incline Dumbbell Press 2x10
Dips 3x10
Shrugs 3x10
Arnold Dumbbell Press 2x10
Barbell Shoulder Press 2x10
Squats 3x10
Lunges 2x10
Calf Raises 2x10
Deadlifts 2x10
Wide Grip Chin-Ups 3x10
One-Arm Dumbbell Rows 2x10
Friday - CARDIO
That's just an example. :)
I like the look of it. Might try and add in lunges again, though I found them tedious last time. Do people here do static lunges or step into them?
This is what I was thinking (haven't sorted out setsxreps yet):
Chest/Shoulder/Triceps
DB Bench
Incline DB Bench
Arnold Press
Lat Raises
Rear Delt row
Triceps pushdown
Leg/Back/Abs
Squats
Lunges
Calf raises
Deadlifts
Lat pull down
Preacher curl
Personally I would take out the lateral raises and do dumbbell/barbell shoulder presses instead as it will hit your triceps too and is a compound movement. :)
I see what you mean, but i've already got arnold press in there which is a very similar movement i.e. working the anterior. I think I might keep that one in, or possibly swap it for Upright rows (haven't tried these, yet they look painful on the wrists!)
