Mondeo fault code - P269F Engine Malfunction
26 Oct 2013
Leicester
Hi all,
Had this fault code suddenly appear on my car :( What a time
I assume it's the fuel vaporiser. They aren't cheap so I'm happy to diagnose a little bit, but is there anything else it could be?
It's a 2012 2.0 TDCI Powershift 163PS
Thanks
First result in a search for your fault code found this:-
Q. A customer’s Ford Mondeo has no apparent driveability concerns but the engine management warning light is illuminated with fault code P269F recorded in the system memory. What could be causing this and how do we rectify the fault?
A. Fault code P269F indicates ‘Exhaust after treatment glow plug – open circuit’. This engine with the Euro V emission system incorporates the Ford Vaporiser system. A fuel injector with a glow plug is fitted in front of the Diesel Particle Filter and when the Engine Control Module initiates DPF regeneration, atomised fuel is injected directly into the DPF filter to aid regeneration and reduce the DPF soot level.
Bearing this in mind, fault code P269F means it’s possible that the failure of the glow plug could have blown one of the control circuit fuses. In the engine bay, fuse box relay number 4 is in the vaporiser circuit and is protected by fuse number 6 on the relay supply voltage on terminal 5, and fuse number 2 protects the supply voltage to the vaporiser and to pin number 34 of the ECM. If the vaporiser glow plug shorts or fails internally, there is a chance that the fuse number 2 will blow. Fuse number 2 has no description on the fuse box cover to indicate what it protects.
Replacing fuse number 2 may fix the issue on a temporary basis but during the next regeneration cycle, when the vaporiser system is again initiated, the fuse may blow again. Instead, the vaporiser should be replaced, but be aware that suitable diagnostic equipment may be required to complete the bleed process. Remember to carry out a road test once completed to check the fault has disappeared and no further problems arise.
This was from the site Ask Harry.
Would this fault being present prevent regeneration from even being attempted?
If not, I wonder whether adding a shot of Eolys with each tank (Like redex in the good old days) might help to protect your expensive DPF until you can actually have it fixed.
(Eolys allows regeneration to take place at lower temperatures)
Thanks. I did see that, but was just more interested whether it could (hopefully) be a simple 'cabling' issue etc with a poorly connected glow plug or fuse
I would imagine so, however I am not using the car at the mo and it will go straight to the garage to be repaired so I don't envisage this becoming a problem
Will either be fuse or the vaporiser itself. If the fuse has blown its likely that the glow plug in the vaporiser has failed anyway though.
OK - thanks. I've found a genuine vaporiser for £118 so I'll go ahead and order that.
Not a bad price that. They're not too difficult to replace, although I wouldn't like to do it on my back on a driveway! Just a single retaining nut, a single pipe and wiring connector.
Yes - look to be £250+ from 'rates-ford' on eBay (dealer) so not bad at all.
