Ford Mondeo ST200
The Mondeo ST200 is based on the Mondeo ’97, with regard to chassis, powertrain and the electrical/electronic systems. The main differences to the existing 2.5 Duratec-VE 24V Mondeo are in modifications to the engine, transmission, body attachments and interior equipment.
The main Technical Features are:
* Modified 2.5 Duratec-24V engine which delivers 151 kW (205 PS).
* Modified intake pipe, larger throttle valve housing with revised transmission ratio.
* New air cleaner with additional intake duct.
* Modified exhaust system with reduced exhaust back pressure, featuring warm-up catalytic converters and underbody catalytic converters.
* Modified subframe and lower suspension arms with modified stabiliser bars (4 and 5-door versions only) together with revised spring and shock absorber ratings.
* Weight reduced flywheel with strengthened clutch.
* Special EEC V calibration to meet exhaust emissions standard Level II and D4.
* Special alarm system (UK only).
* Revised 5th gear transmission ratio.
* Modified RS styling package.
* Recaro sports seats with fabric/leather upholstery and side airbags.
* Modified fuse box.
