- 4 Apr 2009
any1 know wat additives best for my mk3 duratec 2.0 petrol as it sounds like i have a clicky tappet or lifter and wat oil been told slick 50 gud shud i use a thicker oil?
its not the dreaded butterfly swirl thats tapping its in the engine its only a slight tapping noise
so if slick 50 is rubbish wats best?
its not the dreaded butterfly swirl thats tapping its in the engine its only a slight tapping noise so if slick 50 is rubbish wats best?
can the butterflys be removed if its them that are tapping?? im going to get the correct oil from ford
