Monitor Advice - 100% sRGB Gamut
DRZ
DRZ
2 Jun 2003
In the top 1%
Hi,
I'm looking to buy two identical monitors and I'm finding it quite hard to find/correlate all of the various monitors available that might fit so I'm turning to you to help me!
My key requirements are:
  • 27-32"
  • 2560x1440 max resolution - 1900x1200 would be acceptable at 27". Absolutely not interested in a 4K panel as that would mean upgrading my graphics cards which means meddling with my WC loop and I just cba with that.
  • MUST support 99%+ of the sRGB gamut. 100% would be ideal, but I'm not going to quibble over half a % here and there! If it supports more than 100% of the sRGB gamut, it must be able to be scaled back to only show the sRGB gamut. Adobe RGB etc is no good to me!
  • I occasionally play games like League of Legends, F1, rFactor2 and Factorio, so response rate isn't a big factor but I don't want it to be a total horror show if I do break out a fast-paced game in the future.
I don't need any bells or whistles - so I don't care about FreeSync/G-Sync or any other stuff like that. Flicker-free would be nice, but isn't an essential requirement.
I'm looking for the CHEAPEST monitor that fits the above criteria - I have no doubt I could spend thousands on a monitor but I'd rather not.
Thanks!
