Monitor Advice/Recommendation
24 Jul 2020
Hello,
I've currently got a 2 monitor setup and I'm looking to replace the two monitors with a single widescreen monitor.
This monitor will be used for office work, gaming and CAD work.
I have a desktop with the following spec
Graphics Card: NVidia Geforce GTX1660 SUPER 6GB DDR6 GPU
CPU: AMD Ryzen 5 3600 3.6GHz 6 Core CPU – 4.2GHz Turbo
The budget I've got in mind is £400/500
Any pearls of wisdom would be much appreciated?
Thanks
Hi, I think you're going to need a bigger budget even coming down to the lower resolution ultrawides of 3840 x 1200 such as:
ASUS ROG Strix XG43VQ
