Monitor Advice Wanted... THX
8 Jan 2010
I'm looking to buy 3 monitors to form an NVIDIA Surround Configuration. Finding the perfect combination is quiet hard. I want 27" 144hz enough Inputs to cover all ports on GCard and good specs basicly. I did want zero or as small a bazel as possible but that don't seem possible at my price range. To get them all on a monitor cost is to much, as I have at a push £400 for each monitor.
So I've narrowed it down to 3x Acer Predator XB270H 27" 144hz
https://www.overclockers.co.uk/acer...descreen-led-monitor-black-red-mo-066-ac.html
But was thinking of getting 2 of them and 1x Acer Predator XB270HA 27" G-Sync 144Hz
https://www.overclockers.co.uk/acer...descreen-led-monitor-black-red-mo-067-ac.html
To go in the middle, Because ive heard good things about G-Sync. Would that work ok with the other 2 would pictures colours etc match good enough to, as I understand it, there basicly the same model. Cant get 3 of them as only 1 Display port lol
Other question if i did get 2x Acer Predator XB270H and 1x Acer Predator XB270HA G-Sync If i wanted to try NVIDIA GeForce 3D Vision Would they match ok as i understand they have to be Identical model numbers to achive 3D vision over 3 monitors.
Thx for any advice :D
Thx For Suggestion, Im not fussed with IPS but want 3 for nvidia surround and cant connect 3 ROG Swifts to GCard and very expensive for 3 of them anyway :D
Anyone else have an opinion? Would be very grateful.
Im now considering these 4, they seem to be my options.
AOC G2770PQU 27" Widescreen 144Hz
https://www.overclockers.co.uk/showproduct.php?prodid=MO-027-AO
Personally I don't know much about AOC.
Asus VG278HE 27" TRUE 144Hz
https://www.overclockers.co.uk/showproduct.php?prodid=MO-040-AS&groupid=17&catid=1851
BenQ XL2720Z 27" TRUE 144Hz
https://www.overclockers.co.uk/showproduct.php?prodid=MO-098-BQ&groupid=17&catid=1851
Iiyama Prolite GB2773HS-GB2 144Hz
https://www.overclockers.co.uk/showproduct.php?prodid=MO-121-IY&groupid=17&catid=1851
Some feedback and advice would be welcome as I want to make the right choice as i'm buying 3 for an Nvidia Surround Configuration.
I'm not sure how good any of there Customer services are, I just know to avoid Acer
thx
