Monitor advice
10 Aug 2004
Greetings all, I need some advice with an monitor upgrade, I currently have the dell G3323D and I dislike this monitor due to the yellow hue it gives off in the corner. I’ve contacted dell for an exchange but they said that it’s fine and won’t replace it, I’ve had the monitor since march and got to the point where I no longer want to keep it.
I have a budget of around £800
I was looking at the SAMSUNG Odyssey Neo G7 43”, the gigabyte M32U and LG Ultra Gear 32GP850​
If there is something that you would recommend, please let me know, I’ve always had IPS panels as I like the picture quality from them but isn’t essential 32” + if possible.
Thanks
Regards
The AW3423DW/DWF. Highly recommend. Or if you want something bigger than 34" and 4K, then the LG c2 42 is also a good option. I've had a quick look and both are a bit over £800, but I'm sure with a bit of searching you should be able to find a discount code or pick them up in a sale.
The yellow hue in the corner is unfortunately an IPS thing (probably, unless the monitor is actually faulty). It's better/worse on certain models, but there's always going to be some level of "IPS glow" :(
The Alienware is a great choice - mine replaced an IPS monitor and it's a huge improvement :)
