Monitor Arm for 24", 32" and 22"
24 Jul 2003
South East Coast
Hello,
Obviously there are many options for the thread title but does anyone have a recommendation for a GOOD monitor arm for 3x monitors, 24" and 32" landscape and then a 22" portrait mode?
Again, many options available and preferably as cheap as possible but so many options and bad experiences with previous arms/mounts (tilt tends to be a problem, always more or less than you want).
Any recommendations?
If your budget allows then buy Ergotron. They are more expensive but super reliable and well-built, last literally decades and have excellent customer service (they often send you screws/mounts for free if they get loose or you lose them). These are the stuff you buy once and they last you a lifetime.
As for multiple monitors, it's always a better idea to get multiple arms. That way you have much better flexibility in terms of position as every monitor can be adjusted individually and you can spread the pressure across your desk, avoiding bending the desk or loosening the arm's mount itself.
