Monitor arm for LG 34GN850?
19 Dec 2009
Hello,
I just received my LG 34GN850. It's absolutely awesome and I'm super happy to have a nice sample.
The only problem is my damn Invision monitor arm doesn't actually fit it; the VESA bracket is too big to fit inside the LG's slot/socket.
Does anyone who has this monitor have a recommendation for the monitor arm they're using with it? It's annoying but what can you do?
Thank you
Would spacers not work??
Okay, so what I did was buy a load of washers and some screws from Screwfix and unfortunately, the Invision MX150 monitor arm couldn't support the weight of the monitor (though my hack job worked surprisingly well).
So in the end, I've ordered an Ergotron LX and an Invision MX450 (the latter being half the price). So we'll see which one works best.
What worked best? And how does it look
The Invision MX450 was so good that it blows my mind that people actually spend over twice as much for the Ergotron. The latter is definitely a nice, attractive piece of kit but that's stuff I don't care about. The MX450 is extremely sturdy, easy to use and I even removed the USB port because it wasn't necessary.
So the Invision MX450?
And that's for a 34"?
