Okay so this might seem a little odd but for my office setup I have an expensive dual gas lift arm bolted to a standing desk and this stand can take up to 2 x 32" screens up to 9KG each.
I currently have 2 x 24" screens and I am looking at making a change, I want to add a 34" curved screen as a primary monitor then rotate one of the 24" ones vertically for emai/chat/web etc and use the 34" screen as the main one for remote connections to the servers and solutions I have to support.
What do you think the chances of getting that to work, I am thinking because the other monitor will be vertical its not going to be an issue, the only problem would be if I wanted them side by side because I probably wouldnt be able to get the other one into a position to not overlap with the bigger monitor.
