Monitor arm recommendation for wall mounting.
29 Jan 2010
London
Hi guys can some one recommend me a arm for mounting second monitor 23" next to me main 32" monitor. Nothing to fancy but gas spring power is needed. Fully adjustable with tilt and swivel so I can place monitor vertically. Some thing like that any good? Duronic DM65W1X2?
The Duronic is a good budget arm. Just make sure you double check the weight of your monitor before purchasing. Most LED's now would fit into that bracket fine. I use an ErgoMounts VisionPro 500 (EMVP501SWM) which is a pretty good gas assisted arm but it is a little on the expensive side.
