Hey all,
I'm looking to upgrade from my current Mission M72 speakers I'm using at the moment. My budget is around £150-£200.
I've had a general look around, and although I don't usually consider new items (budget constraints and all), the Monitor Audio Bronze Reference 2 (or BR2 for short) seemed to be a very good option to go for.
I've also heard the B&W DM602 S3 is a tough contender too, but I'm not sure if it's actually any better, and would probably be out of my price range even used.
For the record, my current main specs (if you need to know sound card or speaker wire etc, just ask):
Mission M72,
Atacama Nexus 6 Stands,
The amp I will be using these with is a class-T type I'm building myself.
All opinions and recomendations welcome!
Thanks,
Peter
Mission M72,
Thanks,
Peter
