monitor broken?
11 Apr 2009
blyth, newcastle
hey all i have this problem with my nec multisync LCD 2080UX+ 20" monitor. i hadent been on my pc for about a week and when i decide to go on it i turn the monitor on and it comes on for about a second very dim then goes off but the power light stays on. i have tried my laptop on the monitor and the same thing happens, i was wondering could it be the port as it has 3 or 4 and im only trieng in one but i cant find a VGA converter to test this theory out if that doesnt work then i will try it in a different monitor (if i can find one) and if not i guess im buying a new monitor wich wont be for a while as i am onl 14 :(
thanks
Rowan :)
English Convertion:
Hey all ,
I have this problem with my Nec Multisync LCD 2080UX+ 20" monitor. I haven’t been on my pc for about a week, and when I decided to go on it I turned the monitor on and it came on for about a second, very dim, and then went off but the power light stayed on.
I have tried my laptop on the monitor and the same thing happens, I was wondering could it be the port as it has 3 or 4 and I’m only trying in one , because I can’t find a VGA converter to test this theory. If that doesn’t work then I will try it in a different monitor (if I can find one) and if it doesn’t I guess I’m buying a new monitor which won’t be for a while as I am only 14.
thanks,
Rowan
you're welcome :D
Sorry for the Double post but;
Could it be a power problem? Try a different Power lead. See if any thing differs
good idea ill use the one out of my pc as i am testing the monitor on my laptop
*EDIT* got a converter will test and reply asap
