Im looking at getting this monitor:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-007-BE
I will be outputting to it using an OCUK X1950PRO with 2 DVI outputs. What DVI input will the monitor have? The graphics card outputs dual link DVI-I. What cable do I need to connect it with the monitor? Will any DVI cable work? Ive heard that DVI-I accepts both DVI-D and DVI-A cables. Will the monitor take the same connection? Thanks.
