monitor calibration software
23 Nov 2009
North Leicestershire
i've borrowed a spyder 3 express of a fellow forum member the express is the basic model where u just basically just plug in a nd press calibrate.
I think the white levels are a little off tho and wondering if their are any free programs i can use to check the white point which should be 120cd/m
i tried installing the colour eyes demo but it said demo license expired, maybe i installed it by mistake a while ago i'm not sure.
So if u know of any software that will work with the spyder and at least let me check the white point then please give me a nudge to a download
cheers bigjim
you can get a trial of BasICColor's software i believe which is pretty comprehensive and should do the trick. can be used with the Spyder3 as well :)
