Monitor calibration
23 Feb 2003
Colwyn Bay
Which would you go for -
Datacolor Spyder4 Pro or X-rite ColorMunki Display & why ?
Both the same price.
Thanks.
Neither. If you want one for serious photo work then you need to up your budget, if its for "fun" then you'll get just as good or in some cases better results just doing it by eye using calibration images.
Is there anywhere you can hire these from because I don't do much colour critical work but I would like to calibrate my monitors every so often as both my external displays are a bit off at the moment.
