Monitor cleaning
2 Jun 2007
Mornington Crescent
I've got two monitors, a HaansG HZ281 TFT, and a Samsung 2253LW LCD, and they could do with a bit of a clean. But I keep seeing all this different information about them about some things which you can't use on TFTs, or something like that. So, are there any wet wipes that I could buy to use on both of my monitors? I had a look but couldn't see anything on OcUK unless I was in the wrong place, but it would be handy to have an idea on what I need to look for from other sites.
Thanks!
Anything a dry microfibre cloth can't deal with, I would just use a slightly damp/moist one instead. No cleaning agents. Anything stubborn, hold the damp cloth to for a minute to help it loosen up, rather than applying force.
If your monitors need more than that.. good luck, but deal with them more regularly in future and the above will suffice.
