i picked up a HDMI - dvi cable adapter from tesco other day for a 'stock must go' type deal for £2.75
, I got it only because that's like £20 worth for less than a fiver ha, however I do actually want to put it to use, but for my missus. She is using my monitor as her laptop screen is damaged and she now has her 360 in bedroom where she only uses either so just a case of swapping hdmi cable(originally had her using a vga only monitor with vga cable for laptop), this is only a temp thing and now I got that cable I wanted to know if:::
I will get a signal if I connected a dvi-vga adapter to the hdmi-dvi cable? I basically want to put the cable from her Xbox, but unless I can get a decent screen for the cost of the cheapest adapter(£4) with dvi port then I am hoping I can sort it this way
That or I fork out a stupid brand new price of £15 and buy the proper Xbox vga cable?
, I got it only because that's like £20 worth for less than a fiver ha, however I do actually want to put it to use, but for my missus. She is using my monitor as her laptop screen is damaged and she now has her 360 in bedroom where she only uses either so just a case of swapping hdmi cable(originally had her using a vga only monitor with vga cable for laptop), this is only a temp thing and now I got that cable I wanted to know if:::I will get a signal if I connected a dvi-vga adapter to the hdmi-dvi cable? I basically want to put the cable from her Xbox, but unless I can get a decent screen for the cost of the cheapest adapter(£4) with dvi port then I am hoping I can sort it this way
.That or I fork out a stupid brand new price of £15 and buy the proper Xbox vga cable?
